Prestressed Guy
- May 11, 2007
- 390
I have an EOR questioning the use of Deformed Bar Anchors (DBA) for uses in seismic connection and cracked concrete. This is based on the Nelson Stud Welding Inc. ESR-2907.
Have any of you run into this issue?
Under 3.1 General: it states "...The use of these anchors is limited to installation in untracked normal weight concrete."
In Conditions of use: "5.10 use of anchors to resist seismic loads is beyond the scope of this report"
Quite frankly, I have never before thought to look for an EAR for DBA's and have used them for years for connections directly out of the PCI Design Handbook for seismic connections.
Anyone ever run into this issue before?
