DELETE ALL IN THE BACKGROUND 2
JeniaL
IL
This code works well with one sheet
Code:
For Each DrwSheet In MyDrawingDoc.Sheets
Selection.Search "Drafting.View.Name='Background View' "
Selection.Search "Type=*,scr"
Selection.Remove (1)
Selection.Delete
drwviews.Item("Main View").Activate
Next
But i want to run thru all the sheets and delete everything in the background view.
In spite of For Each DrwSheet ....next, it's not going to next sheet.
Any help will be appreciated.
Cheers.
Try this:
Code:
Sub DeleteTexts()
    Dim doc
    Set doc = CATIA.ActiveDocument
    Dim sheet
    Set sheet = doc.Sheets.ActiveSheet
    Dim views
    Set views = sheet.views
    Dim view, textboxes, i
    For Each view In views
        Set textboxes = view.Texts
        For i = textboxes.Count To 1 Step -1
            textboxes.Remove i
        Next
    Next
End Sub
Tesak
- Curved text for Catia V5
Thanks a lot. This is exactly what i need.
Ferdo said:
Set mySelection = DrwDocument.Selection
mySelection.Search "Drafting.View.Name='Background View' "
mySelection.Search "Type=*,scr"
mySelection.Delete
This is works pretty well but requires drawing sheet to be fitted on screen in order to to delete all entities. I tried to add command to fit drawing on screen and here is the issue comes. When fit all command is executed macro keeps to run and doesn't wait for Catia to finish fitting all drawing sheets on screen. Sleep command doesn't helps me. My goal is to delete everything from background except background view.
Well this works not as i expected. I juts used twice For...Next. To fit all sheets in takes some time in Catia but code keeps to run to next loop that is deletion.
How about this?
Code:
Sub CATMain()
Set DrwDocument = CATIA.ActiveDocument
Set DrwSheets = DrwDocument.Sheets
For j = 1 to DrwSheets.count
    Set DrwSheet = DrwSheets.Item(j)
    DrwSheet.Activate
    CATIA.StartCommand "Fit All In"
Next
MsgBox "STOP - Give me a break :-)"
For i = 1 to DrwSheets.count
    Set DrwSheet = DrwSheets.Item(i)
        DrwSheet.Activate
    Set DrwView = DrwSheet.Views.Item("Background View")
        DrwView.Activate
        Dim mySelection As Selection
        mySelection.Delete
        DrwSheet.Views.Item(1).Activate
Next
MsgBox "Let's fit all in again"
For z= 1 to DrwSheets.count
    Set DrwSheet = DrwSheets.Item(z)
    DrwSheet.Activate
Next
End Sub
Fernando
- Romania
- EU
i tried to use sleep instead of message. for the second example i get macro works much faster that catia and i don't actually get all drawing sheets fitted in. definitely that is because i remotely connected to my work PC. i'll give it a try tomorrow when i get to work.
Thanks Ferdo for your help.
Cheers.
if you google shellandwait you can have catia to start another process and wait for the return of the process before continuing... I m using this in some script where I unzip a file in a folder... had to make sure all unzipped before starting to do anything.
Eric N.
Thanks itsmyjob for shellandwait. I'll google for that. Don't want to start a new thread so I'm asking this question here.
I want to put a logo on my title block but i don't want to load a picture from local or network drive. Is there a way to store a picture inside VB6 project and then grab and insert it into Catia drawing?
