Delete hole in surface in NX 9.0.2.5
tryitagain
28
Where do I find the function for deleting a hole in a surface?
In 8.5 in was under the "untrim" menue. Since the menue has changed is it located somewhere else?
which NX version, you are looking for?
GANESH KOTHAKOTA
CAD/CAM LEAD
NX8.5, Vericut7.3.1
TECHMAHINDRA Inc
Probably. You can use the command finder if you are having trouble locating commands that you have used previously.
Besides the "untrim" command, you might also try the extract face command (with "delete holes" option checked) or the fill surface command.
www.nxjournaling.com
The absolute fastest way to remove a hole(s) from a surface, particularly if there are more than one hole but you do not want to remove them all, is to use the 'Delete Edge' function. Simply select the 'edge' of the hole(s) that you wish to remove, hit OK and you're good to go.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks a lot, that was the function I was looking for!
