Hello, I have a gas depressuring system in wich a pressure vessel has to be depressurized from about 29 bar to environmental pressure, using a pressure relief valve.
This is the question and I wonder if you could help me: do you know a mathematical model that is able to tell me what is the minimum temperature value of the pressure vessel wall? I mean: if the gas reaches a minimum temperature value of -50°C at the end of the depressuring process, may I know what is the minimum wall temperature value?
This point is very important for me, because the wall material choice in the vessel depends on this minimum temperature value.
Thank you
Thank you
