patstructural
Hello everyone,
I am a recent grad in Ontario (Canada) working for a company where I am their first hired structural engineer, they have other engineers.
I have been tasked to design a platform (more like a plate) between two wooden plates, see attached image (blue highlighted area is where the plate will be, for maintenance purposes; and ladder is meant to provide access to the elevated wooden plates). I designed a slab, beams, columns in school and even a building in my last year so I am comfortable with the knowledge/experience I gained and I am sure it helped. However, I would like to confirm if my design/analysis approach for this task is correct or not, since I have no experience designing neither at school. Additionally, the task is for a US project and I believe I will have to use their standards/guidelines/regulations.
1. Plate considerations:
Design
a. Location
- Seismic? _ I don't think this should be an issue but could be wrong.
- Code requirements? (US equivalent of CSA Design)
- Avoid clashes/interferences
- Dimensions (28"x14"x5")
b. Capacity
- Max loading conditions at supports
- Construction joints (bolted)
c. Use
- Anticipated loading conditions on platform (check code!!!) - DL (self-weight) + LL (300 lbs from maintenance crew)
- Protective railings?
- Steel/aluminum/wood to wood? _ I took steel and wood design courses but I'm more comfortable with steel.
Analysis
- Slab
- Slenderness _ Isn't this normally a column consideration plus the steel plate is fairly small where I don't think a slenderness ratio matters.
- Min bolts
- R factor? _ Based on research, this is related to seismic. I took a seismic course but I didn't cover this.
- Deflection
- Drift (caused by seismic)
- Buckling _ Since buckling is from lateral or compression loadings at supports, I assume this is a non-issue.
2. Ladder (Fixed) Considerations:
Design
- Material (steel/aluminum?) - slip resistant
- Dimensions (The width of the ladder should not be less than 600mm?; height from floor to wooden plates = 5' 6")
- Loading condition
- Supports (welded between rungs and side rails; bolted/anchored at bottom and top)
- Codes and guidelines (OSHA + others)
**Do not use a metal ladder when working with electricity or electrical current
Analysis
- Moment frame
- LTB (Lateral-torsion buckling) - lateral loading
OSHA Fixed Ladder Requirements
- 10" minimum and 14" maximum spacing from centerline to centerline of rungs. Note: ANSI A14.3-2008 calls for exactly 12" spacing of rungs (the first rung can be up to 14" from the floor surface.)
- The minimum clear width of rungs on fixed ladders shall be 16". Note: The International Mechanical Code 2018 (306.5.4) calls for a minimum of 18" between rails. This width increases to 24" clear at the top of the ladder where the side rails extend 42" above the deck.
- For 90 degree (vertical) ladders, there shall be 30" of clear space on the climbing side.
- Fixed ladders shall not have a pitch greater than 90 degrees.
- Extend 42" above the landing or access level? (check)
I would be happy to provide any additional info to the best of my abilities. Thanks for the help.
Design
a. Location
b. Capacity
c. Use
Analysis
- Slab
- Min bolts
- Deflection
Design
- Loading condition
Analysis
- Moment frame
