aakalim152
- Dec 16, 2011
- 12
We are designing the concrete encasement around a steel pen stock for internal loads. Although the pen stock is capable of taking the loads, but we need to find how much load will be transferred to the concrete encasement. Maximum internal water pressure in 6.5 ksi. The steel pipe material is ASTM A 537 class 1, and the concrete lining is 16 inch thick. Concrete strength is 3ksi.
I have been asked to make a computer model for finding the stress in concrete lining. I prepared a model in sap2000 using layered shell element and then applying internal load. But the answer i am getting are not satisfactory. The resulting stresses in steel are 250kis and in concrete 30ksi (in the S11 direction i.e. local 1 axis), which i think are too high. I am not sure weather a 6.5 ksi internal water pressure can cause such high pressures in the shell.
Also if someone can provide reference to any standard or manual for the design of such concrete lining, it would be really appreciated.
