Design Table and Tolerance
Guano208
I have a part with multiple lengths that seem perfect for a design table. When I label the dimension "A", I loose my tolerance callout in the dimension. I would like the dimension to read A +/- 0.03. Is there any way to make this happen, or do I have to add a tolerance column to my design table even though the tolerance is the same for every length?
Your help is greatly appreciated.
-Morgan
Actually, I figured it out. I was deleting <DIM> and replacing with A. I just needed to overwrite the dimension with A in the form above. Silly.
Morgan
