Eren Jaeger
- Dec 28, 2018
- 28
I just have a question regarding ASCE 7-10 Sec. 27.4.6 Design Wind Load Cases. Case 1 is understandable wherein wind loads were applied only in one direction but for cases 2-4 , I am somewhat confused for the application of roof wind loads. Wall wind loads were just a combination of wind pressures from two different directions applied on different surface areas but, in the case of roof, let's say, Wy for roof is applied for the whole surface area of roof. Same goes for the Wx for roof. So basically, if I apply cases 2-4, Wx and Wy for roof is applied for the same surface which is like applying twice the wind load (though I know, they are different in values). What do you usually do for the roof wind loads applying Sec. 27.4.6?
I hope I am clear in what I am trying to say. I would appreciate your inputs. Thanks!
