braclark
- Jan 25, 2002
- 4
I'm trying to design a heated disc that rotates slowly and I have a couple questions. The heater elements are to be mounted on the rotating disc and it is desired that a slip ring will supply the 120v 10A power for them.
Does this disc have to be "Hard wired" grounded or can I use a slip ring contact to ground it?
Are there any other methods (besides IR) of getting the temperature back to the controller since most slip rings aren't compatable with thermocouples?
