lcw818
Geotechnical
- Dec 6, 2006
- 6
1. When calculating NPSHa: Do you use theoretical suction lift 33.9 feet or practical suction lift around 25 feet sea level?
2. I have an 8-inch suction line that is horizontal at the pump location and below the inlet to the pump. the pump is a 3in x 3in so I have a concentric reducer from the 8-inch to 3-inch. Currently it is also horizontal then goes thru a 90 and up to the level of the suction inlet on the pump. There is concern we are trapping water in the top of the concentric reducer. Can I turn this reducer up to vertical?
luke
luke
