MToomey
- Dec 2, 2019
- 14
Hi folks,
I have been digging around in the forum and on google, but I haven't found a definitive answer to this question. I figure if I had this much trouble finding an answer, it might be worth getting this discussion going.
Is there somewhere in Y14 (likely in .35?) that forbids the placement of a revision symbol within the bounds of the title block?
Say we are changing the material of an item; we would update the material in the title block and note the change in the revision table, and then add a revision symbol to material field of the title block.
I would be tempted to say that a symbol is not necessary as the change of material is noted in the revision comments and the title block is the only location the material is identified, but our internal drafting standard calls for adding a symbol near any controlling information that has changed (reference dimensions do not need symbols for example).
Ultimately, the question comes down to whether it is acceptable to put revision symbols in the title block or if they should be near the border of the title block to note zone A1.
Thanks,
Matt
Thanks,
Matt
