genericmech03
I thinking of using ultrasonic or x ray porosity detectors to pick up porosity in aluminum die castings. The porosities are located under the surface of a raw casting so we currently only find them after we machine them. We would like to detect porous parts before wasting money on machining. The material thickness of the aluminium casting ranges from 25mm to 3mm and the porosities we want to detect range roughly from 0.4mm to 2.0mm in diameter. The surface of the casting would have a degree of roughness (a maximum being Ra=8) and is also curved, smallest radius being 3mm.
Has anyone had any experience, success or otherwise regarding this
Ideally I'm looking for a quick check performed by hand on the suspect areas of the casting, for each part.
