Hello there
I want to implement pump interlock on when the tank level reach a certain limit the pump trips.
Note : tank is not pressurized
Suction pipe length :5 meter
Suction pipe diameter 3inch
2 90 degree elbows
Suction pipe material vc
1 Suction manual valve : butterfly
Media : water
How do I know the minumm level that the pump can safely operates without cavitation
Pump manufacture :grundfos
Pump type : Crn20-4afgj-a-e-hqqe
Attached pump curve with npshr
2 90 degree elbows
Media : water
