Is it possible to determine the power factor of a motor when you only have the amp reading off of the motor? Is there a way to interpolate the approximate power factor from the amps reading only?
We have a motor on an air compressor with a GE Multilin meter. The meter has CTs, but PTs.
The motor is drawing between 24 and 30 amps at 4160V.
Toshiba has told me that the power factor is 83.9 when the motor is at full load.
Here is the motor nameplate data:
Toshiba World Energy Series
2300/4160V
60/34A
250HP
1.15SF
1775RPM
40C Continuous
Thanks!
2300/4160V
60/34A
250HP
1.15SF
1775RPM
40C Continuous
Thanks!
