I am into process engineering and part of my job involves specifying
thermophysical data and flows for various safety valves.Currently I am working on a process which contains C1-C4 hydrocarbons.I have this process fluid which is vapor at normal condition but when I flash it adiabatically to a higher pressure i.e. at its relieving pressure under a blocked outlet condition I get a two phase fluid.Now when I am reporting data for the the relief valve should I take into account DIERS criteria or simply report data for two phase flow
