svizoman
Automotive
- Jul 18, 2016
- 10
Besides known EGR principle to lower NOx and partly to heat up engine quicker will there be any benefit to warm air intake throuh exhaust heat exchanger. By ideal gas law higher than compression ratio higher the efficiency of the engine (of course CR engines in practise has retard injection to some point thus extraction of heat does not start at TDC). If the air itake is warm up by the hot exhaust the overal efficieny would'n increase since from the gas law thermal efficiency is difference of temperatures at TDC and BDC and if the intake air is hotter that only means that exhaust would be hoter but temp differences of TDC and BDC would stay the same (in theory).
So this would only gain efficiency if we used combined cycle where we'll use exhaust heat to make steam and run steam turbine.
Also some exhaust kinetic energy (when exhaust valve opens there are still some pressure, round 5 bar) can be extracted via turbogenerator (turbine wheel powering alternator).
