Difference between wood and steel beams in theory 2
LittleInch
Petroleum
Mar 27, 2013
22,454
There was a recent post here which disappeared as the poster was asking for a design, but I was intrigued enough to do some research into this.
So on a theoretical level, if a wooden beam ( the example was about 4.5m of 4 x 12, so basically half a tree) is accepted by various parties as being sufficiently strong to resist loads and deflection limits, how do you show that a substitute square steel tubing 2 x 10 is as good?
Looking at deflection calcs the term EI as a denominator is always there.
So ignoring anything else, is it simply a matter of showing that if the EI of the steel tube is bigger than the EI of the wooden beam then it is at least as good?
I did some quick calcs and using an E of 10 GPa for wood and 200 GPa for steel plus the I calculation, the steel bean was about twice as good in terms of deflection calcs and I would assume similar for bending moment / shear etc. Of course it is harder to nail other bits of wood into the steel beam, but you take the rough with the smooth.
Does that work as simple ready reckoner? This doesn't mean you can design anything and still need sign off etc but does it work?
1503-44 said:
Basically yes, for deflection you compare EI.
Wood creeps, which can double or triple your deflections.
This is done relatively routinely in remodeling houses; say you want to replace two sets of windows plus sliding door with a REALLY long folding door feature, which means removing existing sections of wall that support the second story wall, so a steel beam is inserted to support the second story wall above the new door.
TTFN (ta ta for now)
^^^ this! I was about to comment about the connections, be careful if you put the hollow section in the slot where the wooden beam was in before.
You might expect problems at the interface wood/steel, unless it's compeltely dried out.
