difference between XV and SDV valves
ipwnftw23
Chemical
Jan 11, 2015
3
I would like to know the difference between XV and SDV valves
i apericiate any help
Typically XV is a simple on off actuated valve which fails in position on loss of power or signal.
SDV is a shutdown valve which typically fails closed on loss of signal our power by using stored energy, normally a BIG spring.
The difference should be shown in your standard p & id drawings
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
