Differential mechanism using "internal" belts, chains
amorrison
605
Anyone aware of these?
Two types found by Googling
"differential belt"
What if there was no space limitation so a loooong "bicycle" chain could be "twisted" 90 degrees if required?
Speculating:
I don't think I've ever seen a 'mule drive' done with roller chain.
It's damn hard on v-belts, so I wouldn't expect long life.
However, I think I've seen drawings of roller chain with twisted links, so the chain could flex in two planes. Never seen it in real life, but ISTR some of Berg's variants on cable chain having the right symmetry to do it, as of course does common 'bead chain'.
Mike Halloran
Pembroke Pines, FL, USA
What aspect of the diff are you trying to emulate - equal output torque on each shaft, or the 90 degree drive, or both?
Cheers
Greg Locock
I have a simple response ... "so what".
Sure, it's conceptually possible ... but so what?
Looks like the overall size and diameter of the mechanism will be considerably greater than for a traditional geared differential.
Greg - mostly relative rpm (+/-10%)control for the output shafts
- 90 degree drive not necessary
Thanks Tmoose - for posting a video site that works for type 2
-- there also is a type 1 diff. video somewhere.
Standard differentials that handle 100-200 hp are pretty heavy - these differentials because of the large diameter gears might be lighter and if operated in a clear environment would not need much cooling oil because of the large exposed to ambient surface.
Comments please.
