Diffrence between 2" sch 40 and @" sch 40S pipe
Ashwani Kumar
12
Q.What is difference between sch 40 and sch 40S pipe,as both of the dimensions like OD,ID & nominal Thickness are same.?
Refer to ASME B36.19M Table 2-1
Note that dimensions are same only for NPS10 (SCH40S) or under.
For NPS greater than 10, dimensions do not conform to ASME B36.10M (not stainless) (NOTE (2))
then why in standard the shedule are wriiten saperately for sch 40 & sch40s separately ,it does have some meaning ?please correct me if i am wrong.
As TuboatEng said, S stands for stainless steel.
Dimensions are same only for NPS10 (SCH40S) or under.
Refer to B36.10M and B36.19M to see the difference.
You can buy Welded and Seamless Stainless Steel Pipe with dimensions conforming to B36.10M.
Technical code related question; is it correct to state that, when
- using B36.10, the right designation is NPS8" STD or NPS8" Sch 40
- using B36.19, the right designation is NPS8" Sch 40S (but not NPS 8" 40S)
Huub
- You never get what you expect, you only get what you inspect.
XL83NL,
Most would write them as NPS8 sch40, with no inch marks.
And I don't believe that current editions of B36.19 list the names of sch (STD, XS and such) only 5s, 10S, 40S, and 80S.
B36.10 does list Std, XS, and XXS for some sizes.
And no wonder that people get confused ......
You're correct Ed, I should've dropped the inch marks (i.e. NPS 8 rather than NPS 8").
However, I think both B36.10 and B36.19 require you to put Sch. ahead of the number.
[ul]
[li]Referring to B36.19 (Im on the 2018 edt.), ch 4. In the 2nd sentence, it continuously mentions Sch. (or Schedule, if you like) ahead of the schedule-number or -designation.
[/li]
[li]B36.10 (again the 2018 edt.) does the same; in the ch 8 it talks about Schedule 80, Schedule 40, etc.
[/li]
[li]Both standards, in Table 2-1, have the same Column name for the schedule numbers: Schedule No.. This indicates that if 40 is used, regardless of what standard is applied, the correct designation requires one to put Schedule prior to the number.
[/li][/ul]
When using the designations Standard, Extra-Strong, and Double Extra-Strong (or STD, XS and XXS if you like), it's been my understanding that (acc. Ch 8 per B36.10) this shall not be prefaced by Schedule, since they're Identifications acc. Table 2-1, rather than Schedule numbers.
Huub
That was partially addressed/answered before. My question was about the right format to designate a certain wall thickness. As I recall, Schedule Standard isnt the right terminology. 40S doesn't seem to be the right one either (although everyone seems to understand what you mean, just like when someone says a B16.5 300# flange).
Huub
Why use schedule at all. It is not required to refer to sch. Be precise and write the wall thickness in inches or mm and avoid use of sch entirely.
The sch designations link directly to the tables in 36.10/19 that list the measured wall thickness and minimums.
And how would you write that? 3NPS x 0.216" aw, or 3.5" x 0.216"aw ?
Thanks,but NPS3sch40 is actually very clear.
Until you try to specify an unscheduled wall thickness.
What is an unscheduled wall thickness? A wall thickness that isn't listed in B36.1x?
Huub
We used to see orders for non-sch wall, usually as minimum wall. These always overlapped a std sch thickness but often with skewed or special tolerances. Such as 2NPS with 0.160" min wall (spec is 0.154" nominal).
