Kodiak31
- Feb 2, 2016
- 7
I'm working on a WWTP's anaerobic digesters originally constructed in the 1960's. The digester tanks have cast iron (CI) pipe with several CI bell end wall castings penetrating the tank walls (photo attached). The bell end/CI plain end joints are made up with oakum/jute and caulked lead (photos attached). Maximum pressure acting on the joint is about 30-ft of H2O. There is evidence of leakage staining emanating from many of the joints.
Our project will replace the CI pipe with new ductile iron. I prefer to maintain the CI wall castings if possible. The concrete around the wall castings is in good condition and cutting the castings from the tank wall may do more harm than good, create leakage points, etc.
Is there a more modern joint or sealing method than could be retrofit to the CI bell / plain end ductile connection in lieu of another leaded joint? Any products or techniques to retrofit a mechanical joint type connection here? Has anyone run into this before?
