NickParker
- Sep 1, 2017
- 435
How should the directional relay (forward/reverse) be set up when cross tie feeders are connected to Switchgear A and B on both ends?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Are you suggesting to use non directional element if there is no differential protection?wcaseyharman said:If there’s no differential element on the bus, you would want to trip for both directions.
