Disc type Thyristor GDT7000 / 06 439722011 Detailed specification
Power Protec
6
I want to know more information about Disc type Phase controlled Thyristor Order code GDT 7000. This Thyristor used in Phase controlled DC Rectifier bridge.
More information makes for a better answer.
Please post up an image of the complete thyristor description (should be either stamped on the part itself or appear in a table in the operating/maintenance manual). Even if all you get is a manufacturer of the device, it's a start.
Converting energy to motion for more than half a century
GDT7000/06 2227 439722 011 This is the information printed on the Thyristor.. I need Manufacturer data and related details.
It's probably a part that was labelled by the manufacturer with a company specific part number. Who manufactured the rectifier it's installed in?
You could contact Iconopower Ltd and ask if they know the part number.
Otherwise, you'll have to match it based on current, voltage and physical dimensions.
They are not attached - they were uploaded but you need to put the link into the message.
It has a QR code. See if a smartphone QR code app will lead to the maker.
No. QR code shows 439722 011 0nly. No other Information
Not available in Astron. Can anyone give the right component and quote.
Perhaps GD rectifiers can help.
Also, who made the equipment this is from?
Please post the diameter of the pole face and the thickness of the package as well as the nameplate of the rectifier. With this information it is feasible to find an equivalent device.
