Hi everyone,
I've defined my displacement using a tabular amplitude. It varies with time. To see if AbaqusCae (Standard) is applying correctly the displacement I go to the history output. However when I see the output results, it doesn't apply the hole displacement: it shows me a maximum displacement applied of 6mm when I've defined with 8mm. Any suggestion?
Thanks,
Ana
Thanks,
Ana
