Nov 26, 2004 #1 427591HJ Mechanical Oct 29, 2004 11 0 0 AT How can I if vthere is a possibility (in Config.pro or somwhere else) set a) View Model>Display >Shade> Quality(10) b) Tools>Environment>Display Style>No Hidden Now I must do that procedure every time I open proE
Nov 26, 2004 #2 gwenn Mechanical Aug 9, 2004 27 0 0 US Hi 427591HJ, In config.pro, set DISPLAY to hiddeninvis. (WF) I'm not sure you can change the shade quality in config.pro, unless it's a hidden config that someone here might know about. you might have to set a mapkey to do it. Hope this helps! gwen Upvote 0 Downvote
