Distance between two circumferential welds in a pipe
Cronos_2P
18
Hi everyone.
In API 1104, ASME or some other standard, is it specified what is the minimum distance between two circumferential welds in a pipe?
Thanks in advance
Do a search on this site as it comes up a few times s year, e.g ams follow a few of the links.
AFAIK, the is no code limit, only company standards and specifications.
Care to expand on your problem?
Apparently, this data is not specified in any standard.
Thank you very much for the help.
You get to exercise your engineering judgement.
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
Normally, experience says 50mm minimum, to have a safe HAZ.
lm
