HuaCl
Chemical
- Jun 4, 2007
- 2
Because this is my first time sizing a steam sparger, I would like to get some outside inputs to see if I'm going about it correctly.
I am designing a steam sparger to be used in a distillation column operating at 17psia (bottom). The steam sparger will be 8" in diameter with 20 holes (10 on each side). Steam enters the column at 45 psia, 9539 lb/hr. My main difficulty have been sizing the holes. To do this, I used Bernoulli's equation for compressible fluid (P1 = 45psia, P2 = 17 psia + liquid head pressure, Cp/Cv = 1.244). My resulting diameter for each hole is 1.27". Does the hole diameter sound reasonable for the desired pressure drop?
Thank you.
Thank you.
