thefamousrockstar
Marine/Ocean
- May 30, 2012
- 5
I am designing an container and did a stick figure analysis. The reaction in one of the supports comes to 56045 N. As per DNV 2.7-1 there should be a check that the bottom side rail does not fail in shear. As the analysis software only gives the reactions/forces at a point only, is it correct that I divide the force across two cross sections as shown (as these would be the two cross sections under shear). This is because the force in the rectangular beam has to be divided into two sections (at each ends). Is this correct? Please advise.
TFR
TFR
