nesamani1983
- Sep 3, 2011
- 23
We have the VSD driven LPG pumps(270 m3/hr & I/L pr=20 O/L pr=70 Kg/cm2 ).
As per the operation seq, disch. valve will start open after 50 secs & speed set has reached. For ex. if 2500 rpm, is set then disch. valve will start open after the pump reaches the 2500 rpm.
Valve opening time is 35 secs.
We feel that running the pump for this 1 min, with disch. valve closed, can create cavitation.so we can install one min.flow recirculation line.
Are we right...? do we need min. flow re-circulation line..?
