Does any body know a quick way to check effective case depth? 1
PhilSBT
Marine/Ocean
Oct 6, 2003
7
After we cold saw the gears and polish the surface to check core hardness is there a chemical that you can put on the surface to let it discolor from were the case hardness starts to were it fades?
Etching with 5% Nital ( nitric acid in alcohol) will give e general guide - but you need a microhardness traverse to be definitive.
