Does it required code case 2901 if the nozzle external loading verified by Caeser II? 11
mechengineer
268
Is it required to use code case 2901 to analyses the nozzle flange again if the nozzle external loading has been verified by Caeser II?
caper656 - my primary recommendation is to not set the design pressure equal to the rating pressure of the flange. Set it to what is appropriate.
Otherwise, stepping up a flange Class may be necessary.
