DR. ABE BLANK NESTING SEQUENCE 1
LaserSpyder
Materials
I got my auto nest to finally give me a descent nest but the sequence is still awful and if I ran it this way I would crash laser guaranteed. does all nesting require some clean up??? or has anyone out there dialed in auto nesting to the point where you can just dump parts in DR. ABE and run the auto nest as they are???? THANK YOU!!!
Well alot depends also on sizes of parts. And also on the table itself.
I have programs i can just nest and run. But as i said also depends on what kind of parts and thickness.
my deal is trying to get the inside cuts E003 to shoot from one cut to the next without passing by already cut hole, and for the sequence to go to the next closest part without passing by already cut part, seems impossible at this point but im not to unhappy at least my nest layout is nice now [hourglass]
I've been fighting it for years. There is a setting where you can choose every hole in the order you want but that defeats the point of auto nesting lol. I'm fighting with offsets right now. they change the hole size the bigger the hole is. Driving me nuts lol
If you figure out how to do that though let me know.
Not really, Ive been using Abe Blank and it's ok. You can partition the entire sheet into parts and then sequence it ie. the direction..Do try it..Also I always try to cut parts individually instead of cutting the sheet. That way, the sequence is set for the individual parts and then the sheet. Here parts are cut and head doesn't move randomly. Using Output Part Grid also helps.
@ Laserspyder try auto cutout avoidance option, if you want to bypass the already cut holes.
