Drafting Files with mixed units failure, NX11
3dr
Automotive
Jul 10, 2004
451
I just reinstalled NX on a new system and the first drafting task I had was mixed units.
To be more specific, I'm drafting one part only, not an assembly.
The base part in mm, the drafting seed file is inch.
When you do this for the first time after an install, you're presented with a dialogue with a yes / no response required.
I clicked "yes" without reading it, so I'm not sure what it said.
It stopped the process of making the drafting file and now I can't even get back to that option again to change it to "no" and make the drafting file.
I did this once before a few years ago after a new install and fixed it. In Preferences, I think.
But I can't find it this time.
Can anyone direct me to the solution???
I think You try find "Reset dialog memory":
Best regards
MANok
NX2027
TC14
Almost correct.
It's Reset "Don't Display this Message Again"
Thank you MANok!
It should just be a warning that the units does not match and "click yes to proceed". Annotating a metric model in a imperial drawing will/should work 100%.
Regards, Tomas
