3dr
Automotive
- Jul 10, 2004
- 451
I’m doing more of this all the time and I’m having issues with the methods I’m using
First, We design the Weldment assembly complete.
Second, That weldment is placed into a parent part for the machining modifications.
Third, That Parent part is loaded into a Drafting file for documentation.
I’m using one of the two methods below to bring weldment solid bodies into the machining parent to modify them
• Promote Bodies
Positive: Works well with the Drafting “Auto Ballooning” tool.
Negative: Drafting “Hole Callout” tool doesn’t recognize holes made in the Promoted body.
• Wave Linked Bodies
Positive: Works well when using the Drafting “Hole Callout” tool
Negative: Doesn’t work with the Drafting “Auto Ballooning” tool.
The component the wave linked body was extracted from needs to be placed on a unique layer.
That unique layer must then be hidden from the drafting view using the “Layer Visible in View” tool.
Can anyone share their best / better practices?
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX1851, Win 10 Pro
• Promote Bodies
Dave
NX1851, Win 10 Pro
