yeagsman85
- Mar 12, 2012
- 30
I have a series of section views on a drawing that I'm trying to sketch on. The problem that I'm running into is I'm also using back clipping on the section views. When the back clipping is active, the sketches on 3 of the 4 views are not visible. When back clipping is turned off, the sketches are visible. I'm guessing this has something to do with the distance specified in the back clipping settings and the "plane" that the sketch is drawn on. Has anyone else run into this problem? Any suggestions?
