I am trying to convert a plus minus drawing to GD&T compliant drawing, first page on the attached file is the original plus minus drawing and the 2nd page is GD&T drawing. Here are the changes:
1. Datum setup
* Top surface is primary datum with a flatness control.
* The lower hole is secondary datum and the tertiary datum is the flat portion.
2. Bi-directional position tolerance
1.548±.010 convert to |position|.020m|A|Bm|C|
.928±.015 convert to |position|.030m|A|Bm|C|
3. Profile tolerance
Dimensions on the upper portion from M to N mostly are 2 place decimals; the general tolerance is ±.015, so I will have a large tolerance
|profile|.020|A|B|C|
Dimensions on the lower portion mostly are 3 place decimals, the general tolerance is ±.005, then a small tolerance selected.
|profile|.010|A|B|C|
Questions
1. Can I add a note “Untoleranced dimensions are basic” to simplify the drawing as shown?
2. How to convert an unequal bilateral tolerance .438+.010-.015 to a basic dimension?
Please let me know all my problems and all I missed, thanks for all of your comments.
SeasonLee
1. Datum setup
|profile|.020|A|B|C|
|profile|.010|A|B|C|
Questions
SeasonLee
