Drawing pattern not exported in dxf
jackorsen88
35
when i export the drawing to .dxf, the drawing pattern is not exported with.
If i export it to pdf is ok.
[banghead]
Please provide more info as to how you're exporting the DXF file, maybe list the steps. There is more than one way to do this (there are internal/external translators in NX) and knowing which way you're doing it may shed some light on things as well as knowing which version of NX you're using.
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.3
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Do you get the same result if you change your setting to 2D instead of 3D?
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.3
Are you using the variable UGII_PATDIR?
NX 9.0.3.4
NX 12.0.1.7 (Testing)
Windows 10
