I'm selecting a metal material for a project in which the metal needs to be ductile (high plasticity) in order to hand-form minor bends, yet rigid enough once formed to hold its shape when small loads (~ 1 lb)are placed on the formed faces. The forming will happen often (perhaps a hundred times over the course of a few years), so it needs to be resistant to fatigue. The metal will be cut into strips roughly 1" x 4-6" x ___ thick (TBD based on ductility of metal, but probably between 1/16" and 3/16"). The bends will be 30-60 degrees with bend radii of 3/4" or greater.
Metals such as Gold, Lead, ,Copper and Aluminum should be ductile enough, but I haven't found much info regarding their resistance to fatigue when subjected to repeated forming of the magnitude described above. Beyond that, Gold is too expensive and lead is too heavy, which leaves only Copper and Aluminum. Does anyone know which would be more resistant to failure in fatigue? Or are there better candidates that I've overlooked?
