Duplex Printing
krz177
14
Is there any option in NX to enable duplex printing? My situation is if I have 2 drawing sheets in a part file, I want it to print double sided. From what I've been able to find it looks as though my options are either using a print initialization file, a postscript setup or export as a appended PDF and print from there. In my testing it appears as though even if I select two sheets from the print dialog and print them at the same time, NX issues it as two separate print jobs.
Has anyone had any success with duplex printing?
I have tried that through the printer properties, That is how I came to realization that NX issues each sheet as a separate print job and not one. I had also thought there might have been and option under under a printbuilder (nxopen) using some options in sourcebuilder, but i came up empty.
Only other thing I do is print to PDF then print double sided from there. Sorry I could not help ya out. Enjoy the weekend.
I filed IR 8295253 for this: "Plot drawings on both sides of a page"
2x NX10.0.3.5 MP7 Mach Design
Testing NX11
on win7 64bit
NX Beta Tester
