jball1
- Nov 4, 2014
- 78
I am trying to validate a dynamic implicit analysis performed in a different software package by running the same analysis in Abaqus. The other software package uses a HHT time stepping algorithm with alpha = 0 (no numerical damping). In order to perform an apples to apples comparison, I ran a dynamic implicit analysis in Abaqus with the following parameters on *Dynamic:
*Dynamic,alpha=0, application=TRANSIENT FIDELITY, direct
I also ran an analysis with Abaqus’s default parameters for transient fidelity:
*Dynamic, application=TRANSIENT FIDELITY, direct
Strangely, the second analysis, which includes a small amount of numerical damping (alpha = -0.05) resulted in nearly identical results to the results from the other program, whereas the first analysis which I thought was an apples to apples comparison resulted in a difference in magnitude of about 20% for the variable of interest, and a phase difference as well.
This made me wonder. When you specify alpha, does the time stepping algorithm change from Hilber-Hughes-Taylor? Abaqus offers HHT-TF (alpha = -0.05) and HHT-MD (-0.333). What algorithm is used if you want an alpha that is not either -0.05 or -0.333?
