struct_eeyore
- Feb 21, 2017
- 263
I'm sure many of you who work in residential see this type of connection often.
The other variation is where the web is packed out with 2x and the joist/floor truss bucket is attached to it.
My question: When trusses come in to one side only, the torsion can get pretty high, especially on wide(r) flange beams. When I'm dealing with approximately equal spans, I usually don't sweat it. Now I have a condition where I have both, a large span, from one side only, and a doubly packed web. I opted out of dropping the beam, and bearing the floor joists over the full flange to kick the load directly into the web. But, I'm curious if any of you have some other means to justify a single sided connection with joist and beams in plane. Thanks
