Eccentricity in Etabs building
umeshlamichhane
13
Does Etabs design the building with calculated eccentricity if it arrises more than 5%(default 5% in IS code) or we have to ovewrite eccentricity if greater than 5%?
You have to manually change it from the default for both code equivalent static and response spectrum cases.
