Economical and safe support system?
CSCPE24
25
Hi All,
Just to preface, I'm a Mechanical Engineer by profession and not a structural engineer. I would like to get some feedback from all you structural experts on a particular concern as outlined below:
I have also attached an image for clarity.
What I have is a platform 3' wide running down the length of a 24' long W10X39 beam. The continuous load for the platform is 155 lbs/linear.ft. Right now, I have 4 of the shown supports evenly spaced within the 24' beam span. The support consists of a C6X6.2 channel attached to the beam as shown with (1) 3x3x3/16 angle. Is this method considered safe and economical from a structural engineers standpoint? Or is there another more efficient and cost effective method?
The 1400 lbs shown is the concentrated load calculated for such a condition for the (2) center supports of the 24' beam span.
I thank you all in advance for any comments and feedback.
Best Regards,
CSCPE24.
csd72
Welding will be the most likely scenario. Angle clips will be field welded to connect the walkway to the tubes.
