Edit 3-D Sketch
Dman5
Automotive
Mar 9, 2011
36
I am new to solid works 3-D sketching. I am up to speed on sketching but am at a loss on how to modify the dimensions I add to the sketch. I double-click dimension with no luck. Any help would be appreciated.
yes, CorBlimey,
It took a minute to figure it out..lol.
Thanks for the reply
I am having a heck of a time using 3-D sketch. I am attempting to design a wire clip, cross-section is 2 mills. It has different angles and planes. Should I use line function or spline function?
Thanks.
Dman5,
You stated you are new to SWX 3D sketching. I suggest you invest in some time to study the tutorials, Help files and online resources.
Next , you might look at what you are trying to do and see if the 3D sketch is the best way to go. I have been using SWX since it came out and in all honesty I rarely need to use a 3D sketch. For one thing 2D sketches are dramatically easier to work with and for another thing I've found that most of what I need to do can be done using the 2D sketches.
Good luck.
- - -Updraft
