I'm hoping if any of you know how to access Edit command (for pre-selected document Part or Product) in Product mode thru VBA script. I tried with CATIA.StartCommand but with no luck...
Well, the command does not work from VBA for all CATIA versions. However, it should work without a problem, if you put it directly into CATIA command window (as "c:FrmActivate"). The trick then is to simulate user input into a CATIA command line either with SendKeys, WINAPI or UIAutomation.
