Edit document in Product with VBA 1
blaR3
8
Hello to all
I'm hoping if any of you know how to access Edit command (for pre-selected document Part or Product) in Product mode thru VBA script. I tried with CATIA.StartCommand but with no luck...
Thanks in advance for your support...
I'm looking for a way to activate/load pre-selected element in product (like double mouse click...)
I tried using CATIA.StartCommand("FrmActivate") but it didn't do the trick... :(
Make sure one object is in selection.
Works for me on 19X from Product to Part and Part to Product
Eric N.
Well, the command does not work from VBA for all CATIA versions. However, it should work without a problem, if you put it directly into CATIA command window (as "c:FrmActivate"). The trick then is to simulate user input into a CATIA command line either with SendKeys, WINAPI or UIAutomation.
Tesak
- Play Tetris in CATIA V5 drawing
