aluminum123
- Jul 9, 2012
- 4
Does bracing has any effect on deflection of beams? I am presently working on an alumunium mullion design which is laterally bracedd by transoms (horizontal members) in a curtain walls. So, whether I should use the span length for deflection calculation from bracket to bracket (which is fixed at the slab at both ends), or whether I should use longest span length between two transoms.
The Height of the mullion is 3.65 meters with bracing provides at 0.7m from the ends.
The connection between the mullion and transom is held by a two screws.
So, should I use the full span length neglecting the bracing as like a simply supported which would render conservative results or whether I can assume the pin support at mullion and transom connection and find deflection by inditerminate beam methods.
Can bracing be consideredd as a support point in the beam?
