davincigee
- Oct 28, 2012
- 50
Hi guys,
I've been pondering over this for a while now. We have 4 pumps connected in parallel. Each pump is connected to a 12" suction manifold by 4" pipelines. 12" pipelines from the tanks are connected to the 12" manifold to supply gasoline to the pumps. Each pump has an NPSHr of 4m yet even at a tank head of 15m (that is the static head when measured from the centre-line of the pump suction inlet to the surface of liquid in the tank) we get these grinding noises or cavitation occurring in our pumps. This is surprising because at a static head of 15m in the tank, it should be enough to overcome all the suction losses and NPSHr and provide sufficient flow to the pumps. Is this a case of some of the pumps getting starved as a result of low flow in their suction pipelines? And how do u determine sufficient flowrate aside the NPSHa calculations to ensure that your pumps are getting enough flow?
