Effect of high viscosity on minimum continuous stable flow
Wkcoo
36
When pumping high viscosity fluid, the corrected BEP shifts to the left. Does this mean the MCSF of my pump will shift to the left also when I am pumping higher viscosity liquid?
Only the pump manufacturer can tell you the effect of higher viscosity on min flow. NPSHr may also be affected.
