Maui
To follow-up Carburize's comments, the earliest publication I can find of the Barsom and Rolfe correlation is ASTM STP 466 published in 1970. A literature search for documents citing that reference should return later work. This is the most common correlation I have seen.
While I understand that there are issues that make correlation between CVN results and KIc results difficult and inaccurate, there is a widely held belief that a positive relationship exists (although perhaps not direct) between CVN values and KIc values, particularly when the correlation is limited to upper shelf CVN behavior. That is, for the same material in the same condition, that with a higher upper shelf CVN will also have a higher KIc. It is this belief that, I feel, supports the belief that materials with higher CVN values will give longer fatigue life. Unfortunately, field performance does not seem to support this conclusion (which, I believe, is what started this whole thread to begin with). The problem I see this creates is that design engineers will specify higher and higher impact requirements believing that this will give them longer fatigue lives. This results in more costly materials and reduced availability. It would seem that a minimum toughness level that prevents brittle failure is all that is required (the original purpose of the CVN test). Requiring higher toughness (specifically, arbitrary increases in CVN requirements) results in increased costs without any improvement in performance.
